My led lights up blue four all notifications except text messages which are white. Is it supposed to be that way?
I've noticed that most apps don't seem to be able to change the notification light to the correct color. Like I wanted Watchdog to make it Red when it alerted for something eating too much CPU, but if I set it to Red, it makes it blue. Just started going thru all the colors it had listed, and finally found that setting it to Cyan actually makes it Red. My Friendcaster alert color is Purple although the app says it should be Green. It's also supposed to flash, but just stays on solid. Seems that the GS3 notification light doen't play well with apps that use it for some reason.
Find yourself version 3.0.5 of the app Lightflow. DO NOT use the latest version 3.1.1 as it will kill your battery in about 4 or 5 hours.
3.0.5 is the only stable version for US S3's and it works well.
