led indicator
CorSa89
Hello :)
In one video in youtube i think i noticed that u can change the colour of the led indicator for the notifications.. i cant remember the video.. but i couldnt find it in my settings.. does anyone knows if this is possible?
Hello :)
Some American models allow this. International does not. There are apps that allow (Light Flow, Light Manager) but IMHO, they're more trouble than they're worth
Some ROMs have LED control built in as well. AOKP has some extensive LED and vibration controls, down to the application level.
Why do think they're more trouble than their worth? I was thinking of downloading one of these. Just curious on what your opinion is :)
Liteflow has been know to cause problem with turning on Talkback and won't go off till you remove Liteflow. Also the colors may not be correct on the US/Canadian version of the S3.
