Hey guys! I hope someone can help me with this because I can't find a clear answer anywhere. Basically, my notifcation light will go off all the time when I have no new notifications. It's so annoying because I never know when I should really check my phone now! Here is a post I put under the Apps category, but it doesn't seem to be getting any responses so I hope it clears thing up a little.... "I hope this hasn't been asked before... I've seen very similar questions, but none exactly like mine. I installed Light Flow Lite to control LED notifications. It used to much battery so I uninstalled it. Since then, my LED light will start blinking about once every ten minutes, but when I check the phone, there is no notification. It just blinks for no reason. This may or may not be associated with Light Flow. I just assume it is becuase the color it blinks is one that I used in that app. I also use the app SMS Pop Up which uses that same color as well. Any suggestions on which app caused it? Really I just want to make it stop because I end up checking my phone a million times a day when I see the light and 95% of the time there is nothing new. "
Please Please Help!!!!
