Apps Led notification app
ownage16
Hello,
i'm trying to make an app that when you press the "Start Led" button, the Led from Nexus 5 phone will start beeping in a certain color.When i try using the app the notification appears in the top bar (Hello World) but after i turn off the screen the Led doesn't start. Can you please help me?
Main activity:
package com.example.led;
import android.app.Activity;
import android.app.Notification;
import android.app.NotificationManager;
import android.app.PendingIntent;
import android.content.Context;
//import android.content.DialogInterface.OnClickListener;
import android.view.View.OnClickListener;
//import android.contect.View.OnClickListener;
import android.content.Intent;
import android.graphics.Color;
import android.os.Bundle;
import android.view.Menu;
import android.view.View;
import android.widget.Button;
public class MainActivity extends Activity {
static final int NOTIFICATION_ID = 1;
@Override
setContentView(R.layout.activity_main);
Button button = (Button) findViewById(R.id.button);
button.setOnClickListener(buttonOnClick);
public OnClickListener buttonOnClick = new OnClickListener() {
@Override
public void onClick(View v) {
String ns = Context.NOTIFICATION_SERVICE;
NotificationManager mNotificationManager = (NotificationManager) getSystemService(ns);
Notification notification = new Notification(com.example.led.R.drawable.ic_launcher, "Hello", System.currentTimeMillis());
notification.flags = Notification.FLAG_SHOW_LIGHTS | Notification.FLAG_AUTO_CANCEL;
notification.ledARGB = Color.BLUE;
notification.ledOnMS = 1000;
notification.ledOffMS = 300;
Context context = getApplicationContext();
CharSequence contentTitle = "My notification";
CharSequence contentText = "Hello World!";
Intent notificationIntent = new Intent(MainActivity.this, MainActivity.class);
PendingIntent contentIntent = PendingIntent.getActivity(MainActivity.this, 0, notificationIntent, 0);
notification.setLatestEventInfo(context, contentTitle, contentText, contentIntent);
mNotificationManager.notify(NOTIFICATION_ID, notification);
@Override
public boolean onCreateOptionsMenu(Menu menu) {
// Inflate the menu; this adds items to the action bar if it is present.
getMenuInflater().inflate(R.menu.main, menu);
return true;
It says the contructor Notification is deprecated and
The method SetLastestEventInfo is also deprecated
