Root LeeDrOid_2.3d_A2SD install problem
HDHNTER
Hi all,
Any help you can provide would be greatly appreciated. New to all of this but I read through the overwhelming info on here before getting started. Successfully rooted via unrevoked, no problems there. SD card was correctly partitioned for A2SD. Trying to install LeeDrOid_2.3d_A2SD via ClockworkMod Recovery v2.5.0.9 & I am getting the following error message.
assert failed: getprop("ro.build/product.device") =="
ll getprop("ro.product.board") == "bravo"
E:Error in /sdcard/LeeDrOid_2.3d_A2SD.zip
(status 7)
Installation aborted.
Not sure what info you need but here is what's listed on Recovery screen:
BRAVO DVT2 SHIP S-OFF
HBOOT-0.98.0000
TOUCH PANEL-SYNT0101
RADIO-2.05.10.08.11
Thanks in advance!
I dont know what exactly it means or how to fix it, but I can tell you one thing.
"bravo" = GSM
DVT2 = CDMA.
Although I heard LeeDroid supports CDMA (no mention in the thread though), the installation has mentioned bravo (gsm) instead of bravoc (cdma).
May be a red herring, maybe not..
Have you asked in the XDA thread.
Yes, I posted in the XDA thread as well. Just got a reply there saying LeeDroid doesn't support CDMA, looks like that was indeed the red herring. Glad I didn't screw anything up..........yet :D
"bravo" = GSM
DVT2 = CDMA.
Looks like the ROM options for CDMA are few & far between. Is it possible to add the A2SD option to my stock ROM since the phone is now rooted or will I need a custom ROM. Really don't want to flash something that's going to be problematic, just trying to avoid future "Low Memory" warnings.
Yes but its a lot of work. You need to enable init.d support.
See faq in Sig
