Jae Son
Hi
Last time I accidentally deleted a system app with the Link2SD app then other system apps started to stop working as well.Then I power off my android then entered in recovery mode and then wiped data/factory reset it.After that,when I restarted my android,it is now suffering on a BOOTLOOP.I don't have any CWM or TWRP recovery installed on my device.I tried flashing stock rom using pc but my pc won't recognize my device even I installed the needed USB driver on my device.The only thing that is accessible right now is the ADB sideload interface but when I tried using this interface and follow those steps on other forums on how to flash stock roms using ADB sideload, the ADB interface on my android just stops working then a message "connection by peer is stopped" appears in the CMD.
I need some help on this problem like other way to flash stock rom or installing CWM or TWRP recovery with just the ADB sideload.
Last time I accidentally deleted a system app with the Link2SD app then other system apps started to stop working as well.Then I power off my android then entered in recovery mode and then wiped data/factory reset it.After that,when I restarted my android,it is now suffering on a BOOTLOOP.I don't have any CWM or TWRP recovery installed on my device.I tried flashing stock rom using pc but my pc won't recognize my device even I installed the needed USB driver on my device.The only thing that is accessible right now is the ADB sideload interface but when I tried using this interface and follow those steps on other forums on how to flash stock roms using ADB sideload, the ADB interface on my android just stops working then a message "connection by peer is stopped" appears in the CMD.I need some help on this problem like other way to flash stock rom or installing CWM or TWRP recovery with just the ADB sideload.
