Hi,
I have an old Lenovo K30-W mobile which is running android 4.4.4 but I am unable to update the OS to a later version.
Needs to be v5 at least so as to run my Google Home MIni & Chromecast.
Google Assistant is not compatible with v4.4.4, so I am hoping that v5 is compatible (Google say it is).
So what I would like to do is:
I would like to find out how to replace v4.4.4 with v5 or later.
I understand that you may need to root the device and as such KingoRoot was suggested, also TWRP needs downloading to 'Flash'!!!
Then I guess I need to download the later android version?
I have no knowledge what-so-ever on what to do or how to do it (If do-able?)
Could someone please talk me through it a non-technical (Step by step) method.
To wipe & rebuild a Windows PC is easy, I am not sure why Android is so difficult & confusing.
Many thanks for any help that you can offer,
Indy
Indy
