Lenovo P70
Guys, who can help us to change the Rom for the Lenovo P70, and let the Gmail and the Android market work.
it has Android 2.3.4 Chinese with English.
settings (the gear ) go through all till you see the word english hook the checkbox go back -> English menus. (it differs from firmware where it is exact)
I searched 30 min. got lost again and again in the menu jungle but finally managed it.
the gmail apps are mostly not compatible with the libs. but try some from homepage of goo-inside.me/gapps
Great, now it
Guys,
I've been looking on many places and finally I found this site (mobileuncle.com) in china, before you download go to google translate to understand their language.
Download this: ?S123??????P70??+google??+ROOT+????_20111026(1).zip????|115??|??|115,????|??????|????|????-??????? you will see 4 colors green, blue, red and white, press on the white to download. Every thing will work very will and you will notice that signal become full and the 3g will work, etc....
Put the zip file in the SD and reboot your phone and press the power and the volume+ and go to the 2nd option (SD) the choose the file press the home bottom twice when finish go to the last option and press home twice will turn off the start it, done.
Hi !
Thanks for your update. Whether all problems listed by me will be resolved ? Can you pl upload the video of procedure in youtube and give us link pl. Waiting for your fast reply....
Guys,
Shall I put the zip file on the SD card or shall I extract it and put all the files on the SD card? I have tried both but without success... :(
Shall the file have a special name (I think the phone search for update.zip)?
Do not extract the file, just put it in the SD and restart, and press the power with + volume and go to the SD option and you should see the file.
The Lenovo P70 is a great dual sim smart Adroid phone. The only mistake the company made, in my view, is that it is NOT a world phone. P70 is only dual band (GSM 900/1800) and will not work, for example, in North America. I bought a Lenovo P650WG dual sim last year and it was a world phone. I also know that Lenovo A60 is a world phone. Consequently, I assumed the P70 is also a world phone when I bought one last week in China, only found out it did not work when I came to N. America. WHAT A SHAME !!!
Hello salemalalili!
Is it the new ROM software or the method to root the lenovo P70 pl? How to take backup of the original ROM in case any problem appears with new ROM you described?
Hello salemalalili!
It's a cocked Rom but like the Original, Send me your E-mail I'll Send you the Original Rom which they sent me from the Seller and the Cocked Rom.
The Cocked Rom is better signal and google with Andrid Market will work fine.
GUYS,
I used This Cooked Rom and it solved all the problems. This the Link:
Press on the white Square below the photo. ( first one from the right)
Google + Android Market + signal and most of the problems will be solved.
Make sure you flow this:
Put the zip file in the SD and reboot your phone and press the power with the volume+ and go to the 2nd option (SD) the choose the file press the home bottom twice when finish go to the last option and press home twice will turn off then start it, done.
GUYS,
Thanks !
You told me that you will send me the original ROM. I gave you my mail id also. I am waiting for the same pl. What are the languages the new ROM will support in the android phone? Will it become the world phone pl? Sorry for asking so many questions... hope you understand
Thanks !
When I tried to install. It says "--Install /sdcard... E:signature verification failed Installation aborted."
What to do now? Pl help...
GUYS,
I cant download from this link, you guys have another mirror, or can you guys upload it to another working page. From the posted link it downloads a bit and very slow, and then suddenly stops.
Thank you.
