LeOs 2.0 or custom
There is no big differences, the custom has some exclusive clovers and transparent desktop.
The big difference is that this custom is based on the latest LeOS 2.0, version 5090, I feel my phone faster using this version.
No big issues so far that I have noticed.
Version 5097 is for 3GW101 and not 3GW100.
None of this versions has market pre-installed, you must use the tutorials found here in the forum to install it.
hi pino how you doin? so is this Version 5097 for 3GW101 the best firmware so far? im still at the version 1.4.1
Hi. From my personal experience, I recommend to you use firmware 5092 for 3gw101. 5097 is only test version a there are lot of bugs. 5092 is ok.
Morz,
Please notice that this version 5097 is for 3GW101, the latest for 3GW100 is version 5090.
Anyway both are much newer and better than 1.4.1
i just received my lephone last week and think that they already modified it. but would really like to know what i must do now to change the os. newbie here dont realy know! but one problem ive notice. the gprs and wireless network cannot work together. when i switch on the gprs/3g, the battery goes down quickly and when i turn if off i must restart the phone to turn it on because without restarting the phone, it does not indicate the 3g. dou you think that its a hardware problem or software.. 2- I looses network very often even with the metal back cover. any solution. please friend.
hello to all
