drive88mph
So since Droid Turbo cases are so hard to find these days in Mexico, I had my phone for a week when I suddenly dropped it and damaged the frame and some other parts of the body.
I managed to get a replacement for the battery door and the frame is very cheap even OEM but I have seen in many videos that you have to remove almost everything to separate the digitizer from the frame using Heat.
So my question goes to the following:
Thanks for your time!
- Is there a way to use only heat and just take off the battery cover so that I can remove the digitizer with the rest of the inside of the circuitry and all without removing anything else?
- Is it better to get the set that costs 200.00 dllrs that has the frame and the digitizer already glued?
- Just not worth it since they are just scracthes? (im a perfectionist I cant take it, honestly)
