Ahmed nagy
Permissions
This application has access to the following:
Hide
- Your locationapproximate location (network-based)
Allows the app to get your approximate location. This location is derived by location services using network location sources such as cell towers and Wi-Fi. These location services must be turned on and available to your device for the app to use them. Apps may use this to determine approximately where you are.
precise location (GPS and network-based)
Allows the app to get your precise location using the Global Positioning System (GPS) or network location sources such as cell towers and Wi-Fi. These location services must be turned on and available to your device for the app to use them. Apps may use this to determine where you are, and may consume additional battery power. - Network communicationfull network access
Allows the app to create network sockets and use custom network protocols. The browser and other applications provide means to send data to the internet, so this permission is not required to send data to the internet. - Phone callsread phone status and identity
Allows the app to access the phone features of the device. This permission allows the app to determine the phone number and device IDs, whether a call is active, and the remote number connected by a call. - System toolsinstall shortcuts
Allows an app to add shortcuts without user intervention.
Hide
- Your accountsfind accounts on the device
Allows the app to get the list of accounts known by the device. This may include any accounts created by applications you have installed. - Hardware controlsprevent device from sleeping
Allows the app to prevent the device from going to sleep.
control vibration
Allows the app to control the vibrator. - Network communicationview network connections
Allows the app to view information about network connections such as which networks exist and are connected.
view Wi-Fi connections
Allows the app to view information about Wi-Fi networking, such as whether Wi-Fi is enabled and name of connected Wi-Fi devices. - System toolsaccess extra location provider commands
Allows the app to access extra location provider commands. This may allow the app to to interfere with the operation of the GPS or other location sources.
run at startup
Allows the app to have itself started as soon as the system has finished booting. This can make it take longer to start the device and allow the app to slow down the overall device by always running.
