Root lg ally on cricket or metro..
flip2405
Well i have figured out the nv item to get the MIP and PPP config i dont see a problem releasing it being's that the phone is almost as old as dirt.. If any mods have a problem with it please let me know i will remove that portion from the post...
What you will need:
Cdma WorkShop --- Newest one (demo will work)...
connect the phone to cdma workshop
read nv item's
39939
Replace the "00" after "07" With "FF" so it should read
07 FF 00 00 00...etc
save txt write nv... settings will now stick..
Here is my problem.. the 3g will connect for a few then disconnect then reconnect then disconnect was wondering if some one has a solution or is willing to work with me to find a solution.. If so you can find me in
irc.freenode.net #ally
User: Flip or Flip_
