andriodadmirer
THIS IS CM10 4.1.2 JELLY BEAN
THIS IS ANDROID ADMIRER HERE WITH GOOD NEWS
I REPAIRED .......
OTA DATA IS NOW WORKING
MESSAGING IS NOW WORKING
AND I REPAIRED THE FRONT CAMERA RECORDING AND GOT IT TO WORK
I'VE BEEN TESTING THIS OUT FOR ABOUT TWO DAYS AND SEEMS TO WORK FINE
WHAT CHANGES I'VE MADE....
1. I ENABLED THE DUAL PANE MODE IN THE SETTINGS.APK (TABLET STYLE SETTINGS)
2. I REPLACED CM CALCULATOR WITH ANDROID L MATERIAL DESIGN CALCULATOR
3. I REPLACED CM SYSTEMUI.APK WITH A MODDED LIDROID 4.2.2 STYLE SYSTEMUI.APK
4. I MODDED CONTACT.APK TO BE SEMI TRANSPARENT SO DAILER/CONTACTS INTERFACE IS TRANSPARENT
5. I INTERGRATED XPOSED FRAMEWORK INTO SETTINGS.APK
INSTALL XPOSED FRAMEWORK BY....
GOTO SETTINGS
TICK XPOSED
TICK FRAMEWORK HEADING
MAKE SURE YOU HAVE AN EXTERNAL SD CARD INSERTED FIRST
THEN TICK INSTALL/UPDATE
GIVE IT SU PERMS
IT WILL TELL YOU IN ORDER FOR THE FRAMEWORK TO WORK YOU NEED TO REBOOT THE DEVICE
DO THAT AND YOU WILL HAVE A WORKING XPOSED FRAMEWORK
6. I INTERGRATED A MODULE FOR XPOSED INTO SETTINGS AS WELL
CALLED XUIMOD THIS MOD HAS STATUS BAR,LOCKSCREEN, AND ANIMATION MODS
TO INSTALL THE MODULE....
GOTO SETTINGS
GOTO XPOSED AND TICK IT
GOTO MODULES AND TICK IT
FIND XUIMOD AND TICK THE CHECK BOX THEN REBOOT AGAIN AND AT THAT POINT YOU WILL BE ABLE TO USE THE MOD
YOU CAN ONLY GET TO THE MOD BY GOING TO THE SETTINGS AND I HAVE IT HEADED AS "MODS"
7. NEXT IS AN APP CALLED HEADSUP NOTIFICATIONS I INTEGRATED INTO SETTINGS.APK AS WELL
THIS IS THE HEADSUP MOD THE YOU HEARD WAS BURIED IN 4.4.4 KITKAT
THIS IS A NOTIFICATION THAT APPEARS FROM TOP OF STATUSBAR OR WHERE EVER YOU WANT AND ALSO IS LOCKSCREEN NOTIFICATIONS AS WELL
INSTALLING THIS IS AS EASY AS OPENING THE APP AND TOGGLING HEADSUP WITH THE GREEN BUTTON
THIS TAKES YOU OVER TO THE ACCESSIBILITY SETTINGS WHERE ALL YOU HAVE TO DO IS TICK THE HEADSUP HEADING TO TURN IT ON AND THAT'S IT
8. I INTERGRATED HOVERING CONTROLS
THIS ARE CONTROLS THAT YOU CAN AJUST SO YOU CAN CONTROL YOUR DEVICE WITHOUT TOUCH JUST AIR GESTURES
THIS IS ACTIVATED BY THE PROMPTS ON SCREEN JUST FOLLOW THOSE I THINK IT'S ONLY TICKING A BOX ONE TIME
9. THE LAST APP I INTERGRATED WAS THE SIDEBAR APP
THIS IS AN APP THAT WE CAN USE TO QUICKLY GET TO ANY APP WE NEED
BY SWIPING THE LEFT OR RIGHT SIDE OF OUR PHONE AND YOU GET AN APP
DRAWER JUST TO THE SIDE OF YOUR SCREEN
10. I REPLACED THE KEYBOARD WITH ANDROID L KEYBOARD WITH MATERIAL DESIGN
HOW TO GET MATERIAL DESIGH IN KEYBOARD LIKE MY SCREEN SHOT IS TO
GOTO LANGUAGE AND KEYBOARD SETTING
GOTO THE SETTING ICON NEXT TO THE GOOGLE KEYBOARD HEADING
AND TICK IT
THEN GOTO ADVANDED SETTINGS AND TICK IT
SCROLL DOWN TO COLOR SCHEME AND TICK IT
AND CHOOSE MATERIAL AS YOUR COLOR AND THERE YOU GO
here is rom
cm10connect
INSTALL INFO
1. BOOT INTO CWM
2. WIPE DATA AND CACHE
3. GOTO MOUNTS AND STORAGE
FORMAT CACHE, DATA AND SYSTEM
4. GOTO ADVANCED AND WIPE DALVIC CACHE
5. GOTO INSTALL FROM SD AND FIND THE ROM SELECT YES TO INSTALL
6. GOTO REBOOT SYSYEM NOW AND IT WILL BOOT UP
*******************THE BOOT ANIMATION IS THE ANDROID L BOOTANIMATION AND IT WILL STOP AFTER IT IS DONE RUNNING THROUGH THE ANIMATION
THIS WILL LEAVE THE PHONE SCREEN BLACK FOR A FEW SECONDS
********DON'T PANIC THIS IS NORMAL IT WILL BOOT UP ************
SO THER YOU GO I HOPE WE CAN GET ON AND START MAKING MORE ROMS NOW !!!!!!
I REPAIRED .......
GOTO SETTINGS
TICK XPOSED
GIVE IT SU PERMS
GOTO SETTINGS
AND TICK IT
here is rom
cm10connect
INSTALL INFO
1. BOOT INTO CWM
