Help LG-E610 stuck after software upgrade with LG PC Suite
xproject
Hello, before writing here I have searched everywhere but haven't found similar problem.
I tried to update LG-E610 using LG PC Suite, but something went wrong. I have NOT disconnected it before PC Suite told me to do so.
On my phone screen is always the same "Download is in progress. Do not disconnect cable." I tried hard reset but it always returns only that screen.
And to make things really bad, LG PC Suite doesn't recognize my phone anymore so I can't restore upgrade errors.
Then I've tried using LGMobile support tool which DO recognize my phone and say that I have latest version of software on it. I tried there to Upgrade recovery and after downloading approx 372MB file when it start to install it on my phone it stop on 4% and report an error with no additional info.
I don't want to root it because it is still under warranty but I'd like to fix it without sending it to service (which will take couple of weeks).
Thanks in advance,
xproject
If you want you can contact me on skype - xproject.skype - to speed up the process.
