Lg esteem metro
Louvit
Member
a few issues
batt use says android is using 98%
if I turn off wi fi or am not at home I cannot send e mails
heres the setings, maybe its a quick fix
also I cannot have 4g and wi-fi at the same time when I use my wi-fi the 4g symbol goes off and also if I turn off wi-fi I cannot use e mail.. I need 4g to watch live tv on my cable service
Your phone will only use one type of data connection at any time. When it connects to wifi, it uses that for the data and will automatically shut off the phones 3g/4g radios to conserve battery.
Your emails should be able to send over your mobile connection. It sounds like theres some configuration issue there
So without the wi-fi on is it correct that I cannot get mail or send mail....also what about post 1 where android is using like 98% of battery...is that normal...
ps thanks
ps thanks
You should be able to send and receive emails while on 3g or 4g just fine. Something is definitely wrong with that.
As per the battery drain, I'd suggest downloading an app called gsam battery monitor. It does a much better job than the stock battery stats app and will help us figure out what the cause of the drain is.
looks like a good app. what should I be looking for...first screen says batt usage 1%
click golf club looking thing bottom left snd it says 7.8% usage consumed by....a list of stuff
That app will keep track of whats using your battery. Its best to charge your phone, let it discharge and check the app before it needs to be charged again.
Once you do that, let us know what it says
