anyone?Can Rogers apps be removed without rooting the phone?
I would highly doubt it, but give it a try. The easiest way to try is to download Astro from the Market. It's a good file manager, similar to Explorer on Windows. It will let you look through folders, delete them, etc.anyone?
Tried using Astro, but when I tried to uninstall moxier mail for example, it said it was unable to uninstall. Maybe I should try rooting. Is "un"rooting an Eve possible/as easy as rooting it? Also, does it void the warranty?I would highly doubt it, but give it a try. The easiest way to try is to download Astro from the Market. It's a good file manager, similar to Explorer on Windows. It will let you look through folders, delete them, etc.
Technically you are voiding your warranty as you're making changes to the OS. However, you can always restore back to a stock Rogers / LG firmware if you ever have to send in your phone. Not sure if it completely reverses the root, but all the Rogers apps will be back.Tried using Astro, but when I tried to uninstall moxier mail for example, it said it was unable to uninstall. Maybe I should try rooting. Is "un"rooting an Eve possible/as easy as rooting it? Also, does it void the warranty?
It sounds like the LG V10N software has extra security when trying to enable root permissions. Unless you can somehow find out what the password is, you may be out of luck in rooting V10N.Hi! When I tap "Enable Root Permission" I'm asked to enter a root password.
i have a GW620 orange with a V10N (installed yesterday by d the software updater agent).
I searched through many forums and very people have the same problem, but nobody knows anything.
Can u help me?
Hi all,
there's a whole section of Roger's links still in my "applications" list. The my5 link, weather, home, stocks, etc.... I want rid of ALL of them, but I can't find where those links live... any idea?
3d2
< Rogers.apk
9d7
< RingsExtended.odex
18d15
< IM_RGS.apk
29d25
< Rogers.odex
52d47
< FaceBook.apk
56,57d50
< Linkbook.odex
< MoxierMail-2.1.20.2-GW620-Rogers.apk
76d68
< MySpace.apk
91d82
< Email.apk
102d92
< RingsExtended.apk
109d98
< Linkbook.apk
118d106
< RogersImPlugin.apk
123d110
< IM_RGS.odex
133d119
< Email.odex
I got rid of most of the Rogers crapola (telenav, moxier*, etc)
It's called tn55-android-LG_eve-2003.apkHow did you get rid of TeleNav? what was it called?![]()
OK, a while ago I said that I would start a thread on how to root the Rogers LG EVE GW620.
All of this information I found through other forums, so I just followed the steps and got a rooted Eve quite simply. All thanks go to the original rooters (Zacpod) and the fine folks over at XDA.
I was using Windows 7 so Vista or XP maybe slightly different, but not a whole lot. Also, I did this a few weeks ago so some of it is going from memory. If any edits are needed I will update this post.
Getting started
First, get yourself a copy of Android SDK (it's completely free) from here: http://developer.android.com/sdk/index.html
Read the installation guide here: http://developer.android.com/sdk/installing.html
You only need to install the SDK, not the Eclipse plugin.
If you're using Windows, you'll also need the ADB (Android Debug Bridge) USB driver. Get it from here: http://developer.android.com/sdk/win-usb.html
Download the LG USB drivers from this link.
Linux and OSX users don't need a driver (lucky you!).
How to install the LG USB and ADB USB drivers on Windows.
This is the part that I had the most problems with, but that's mainly because I read the instructions wrong!
First, install the LG USB drivers from the link above.
Then, on the phone you need to enable USB debugging mode
Settings ---> Applications ---> Development ---> USB debugging (put a check mark here)
Connect the phone to your PC with the USB cable.
In Windows, you should hear the beep on a connected device and the LG drivers should find it OK. In Windows, open up Device Manager and you should see 2 devices with yellow exclamation marks beside it and the description "LG USB Modem" (I'm going from memory here, so that may not be 100% accurate).
Right click on the 2nd one, click "Update driver software", click "Browse my computer for driver software" then click "Let me pick from a list..." You should see "Android Phone" listed. Double click this and you should see a list of 3 options. Click on "Android ADB Interface" and click "Next". You'll probably see an "Update driver warning" box, so just click "Yes" to install it anyway.
If you don't see 3 options, click "Have Disk..." and select the Android USB driver (android_winusb.inf) you downloaded earlier.
After all this, you should now be able to get ADB shell access to your Eve. To check you have access follow these steps:
If you're on Windows, open a Command Prompt window but make sure you "Run as administrator" to get the privilegies needed. Linux users can use Terminal.
Navigate to your installed Android SDK (ie: "cd c:\SDK\tools\" if that's where you installed it).
Now type "adb devices" to see if your Eve is detected. If it is, you're good to go on.
Rooting (all credit to Zacpod)
Now onto the actual root. All this is taken from Zacpod's excellent post found here: http://androidnetwork.org/forum/viewtopic.php?f=22&t=143 I'll be copying it almost verbatim, and I hope he doesn't mind
Navigate to your installed Android SDK (ie: "cd c:\SDK\tools\").
- Download the Superuser Whitelist (http://koushikdutta.blurryfox.com/Superuser/Superuser.zip) and unzip it somewhere safe such as c:\SDK\tools\
- On the GW620 dial "3845#*620#" to get in to the secret menu
- Tap "Module Test" then tap "Stability Test" then tap "Enable Root Permission"
- Open a Command Prompt on Windows by pressing Windows Key + R, then type "cmd" in the empty field. Note, you should also run this with Administrator rights. Linux users can use Terminal.
You will now have root access to your Eve and can now remove the Rogers apps.
- Type "adb shell"
- You should get a #. If you get a $ then something didn't work. Shutdown the phone and PC and try again. If you get a # then all is well. Type "exit" to return to your PCs command prompt.
- Type "adb remount" to remount the GW620's file system as read-write so we can make changes.
- Type "adb shell cat /system/xbin/su > /system/xbin/su.original" [Note: This step may give you a "could not find path" error. Just continue on with step 5 and the root will still work.]
- Type "adb push bin/su /system/xbin/su"
- Type "adb push bin/su /system/bin/su"
- Type "adb shell chmod 4755 /system/xbin/su"
- Type "adb shell chmod 4755 /system/bin/su"
- Type "adb install bin/Superuser.apk"
Removing the Rogers apps (credits to the people of XDA)
- Make sure your phone is in USB debugging mode (see beginning of guide).
- In the Command Prompt (or Terminal on Linux), make sure you're in your SDK Tools folder (c:\SDK\tools\)
- Type "adb shell". You should see "#"
- Type the following commands:
Code:adb remountCode:mkdir /sdcard/backupCode:cd /system/appThis backs up the MoxierMail app onto your SD card.Code:dd if=MoxierMail-2.1.20.2-GW620-Rogers.apk of=/sdcard/backup/MoxierMail-2.1.20.2-GW620-Rogers.apk
Code:rm MoxierMail-2.1.20.2-GW620-Rogers.apkAgain, creates a backup of the Linkbook app onto your SD card.Code:dd if=Linkbook.apk of=/sdcard/backup/Linkbook.apk
Again, creates a backup of the Linkbook app onto your SD card.Code:dd if=Linkbook.odex of=/sdcard/backup/Linkbook.odex
Code:rm Linkbook.odexCode:rm Linkbook.apkCode:dd if=MySpace.apk of=/sdcard/backup/MySpace.apkCode:rm MySpace.apkCode:dd if=RingsExtended.odex of=/sdcard/backup/RingsExtended.odexCode:dd if=RingsExtended.apk of=/sdcard/backup/RingsExtended.apkCode:rm RingsExtended.odexYou're done. Stay in the ADB shell for the next part.Code:rm RingsExtended.apk
Enable deleting of pre-installed bookmarks
In ADB shell, type:
Code:cd /data/data/com.android.browser/databasesThis will allow you to delete the Rogers bookmarks.Code:sqlite3 browser.db "update bookmarks set readonly=0;"
Type "exit" in the ADB shell to return you to the Command Prompt.
Hopefully this should help out a few people that want to root and remove the Rogers apps. You may have problems with the Windows USB driver getting recognized as I do all the time. I have to keep re-installing the ADB driver for some reason, but it get's there eventually.
Good luck!
Hi all;
Im new to this,so apologies in advance for any obvious bonehead moves.
Im following the instructions so kindly laid out by britbloke, but....... my xp sp2,with lg drivers installed and showing up in Device Manager will not show android phone in list , nor will it show me sdk usb driver to update driver with. I have usb debugging enabled, and root permissions enabled. I am following britblokes instructions to the letter as far as I can tell. Any thoughts?
rootless in Vancouver
I get the same error..
Edit: LOL I got it. I just placed the bin folder in the wrong place in Windows.
OK, so now I am rooted. I have heard that this helps if you want to install paid applications. But if I look in Market now, I still get only freeware or adware..
I am stuck on step 9 -[FONT="]Type "adb install push [/FONT]C:\Users\Masu\Desktop\Tools\android-sdk-windows\tools\Superuser\[FONT="]bin/Superuser.apk"
When I enter this commad I the following error:
177 KB/s (18880 bytes in 0.104s)
pkg: push
Failure [INSTALL_FAILED_INSUFFICIENT_STORAGE]
Any ideas or suggestions?
[/FONT]
