LG Eve Wallpaper Resolution
What is the resolution for the LG Eve? I thought it was the screen resolution but it's more of a widescreen type picture. Does anyone know what the resolution is?
A quick search came up with this:
"...a 3-inch resistive touchscreen, with a resolution of 480 x 320..."
is that what you are looking for ?
~Annie
i appreciate your help but that wasn't what i was looking for. At first i thought it was 480 x 320 for the wallpapers but if you look at the default wallpapers, it's more of a widescreen because of the fact that you can slide on screen to the other
get any wallpaper that have the same proportion or so of 2560x1920 or 1600*1200 and you will be fine.
just tried 1920x1200, wasn't tall enough for the whole thing to fit. when i tried to crop it when selecting the wallpaper it reached the height limit but there was still sum width left
