Root LG Exceed2 (VS450PP) Stock ROMS: Deodexed & Unmodified
Status
Not open for further replies.
bcrichster
ROMinator
Moderator
Recognized Developer
LG Exceed2 VS450PP
Verizon Wireless
OS 4.4.2
Warning! Anything you do with your own phone while Rooted runs the risk of bricking your device.. including flashing this ROM or other ROMS. You do this all at your own risk. Therefore I AM NOT RESPONSIBLE for bricking your device!
These are
UNTESTED ROMs, so please make a Nandroid backup before flashing!!
Unmodified (No Root) - Uploading..
Unmodified (Rooted) - https://www.androidfilehost.com/?fid=24052804347815592
Deodexed Only - Uploading..
Deodexed Debloated - https://www.androidfilehost.com/?fid=24052804347815744
For those of you that managed to brick your device, here's the route to the kdz file you'll need: http://androidforums.com/index.php?posts/7065335
CREDITS:
- @SuperR for giving me the tools and direction to try this project
- @Father Guido for uploading the needed files, suggestions and testing
- @DigitalKnight for pointing the way to the kdz file
* If you like the work, hit thanks in the OP! *
Doesn't Flashify bypass locked bootloaders..? Oh, wait.. All should be rewritable in recovery, correct?
to be honest if you are not modding the stock boot.img it should not need bumping, but if you are using a modded one which it seems your are, then the image needs to be bumped or the person needs an unlocked boot loader
OK then.. Unmodified should be untouched. I'll redo the deodexed ROMs and leave kernel untouched
Okay.. I done some research and found out about "Bump!" Requirements for these LG devices. Redoing everything tonight and will upload tomorrow. Thanks SO MUCH @hroark13 and @SuperR for pointing fingers & showing me something new!! You guys Rock!
Op updated, added Unmodified w/Root. boot.img was untouched
Will upload bumped boot.img later tonight
My exceed 2 is out of space even though I moved all the apps that let me move them to the SD card and store my photos on the 32gb SD card.
So I am thinking about trying the debloated rom. Anyone know how much room it frees up on the phone? Anything I need to know or that I will lose?
I get "750 and 760 boot error" from the debloated Rom then a black screen?
Was able to do a factory reset (vol- and power) and it restarted into TWRP and restore from a backup I did when I rooted and get back up and running.
Not sure why the debloated Rom did not work.
Thanks for the info.. Are you possibly using a similar device for a different Carrier? I posted these as a help for @Father Guido and others... Maybe that's why he said he needed to fix something
Verizon LG-VS450PP
HW Rev 1.0
Android 4.4.2
Baseband - M8610B-AAAANAZM-1.0.6035
Kernel 3.4.0+
Build KOT49I.VS450PP1
Software VS450PP1
I did install the latest software which is VS450PP2 but it is not rootable so I downgraded with help from FatherGuido.
He is very busy so I thought I would try it out first but no luck.
Going to try and use Link2SD and Titanium Backup today to free up some space, again thanks to FatherGuido for his points on using those.
One day I might get into creating ROMs so that I can contribute more.
Verizon LG-VS450PP
HW Rev 1.0
Android 4.4.2
Kernel 3.4.0+
Software VS450PP1
i need to down grade mine also.if you can share the info it would be good
If you share the link, I'll certainly post the kdz link in OP. @Father Guido is a very busy man but he's your best chance of help since I'm very ignorant with LG devices to this point and have no idea what methods he used to downgrade
LG Exceed2 VS450PP
Verizon Wireless
OS 4.4.2
These are
CREDITS:
i flashed this with twrp and got a memory access error at boot
Status
