Hi all
I made a TWRP 2.8.6 for LG Exceed 2, I am pretty sure it will work on the Realm as well.
Must be rooted, must have unknown sources enabled
Copy apk to your phone and install it
Open LG W5c TWRP app
Click Install Recovery (this only needs to be done once)
Click Reboot Recovery to reboot to TWRP
To Boot to TWRP from an off state
(THIS ONLY WORKS ON THE EXCEED 2, IF YOU DO THIS WITH THE REALM IT WILL AUTOMATICALLY FACTORY RESET THE PHONE AND YOU WILL LOSE YOUR DATA, SO ONLY DO THIS ON THE REALM IN EMERGENCIES)
Pull Battery out
Put Battery back in
Hold Volume Down and Power until a white screen comes up
You should get 4 options
Use Volume Down to select Wipe Cache
Press Power Button
It should then go into TWRP
Download
http://www.mediafire.com/download/8dt1pxf4g8477n5/lg_w5c_twrp_286.apk
If I have helped you, and you like my work, please click on the Thanks Button and give my thread a rating by clicking on the stars above.
If you would like to buy me a beer , you can click on the PayPal button
I would like to thank the following people for their donations
Pull Battery out
Put Battery back in
Press Power Button
Download
