Help Lg g2 help!!
Hi. I dropped my g2 and now there is black vertical lines. Help? Is there a way to fix this? Or do I have to physically replace something?
It's not sounding good. You might try to lightly de_stress the display by grabbing it in landscape mode with two hands and wringing it ever so slightly, and then taking the thumb of one hand and pressing on the perimeter of the display and running it all the way around with a little force... it sounds like the display could be permanently damaged.
Good luck.
Unfortunately, it doesn't help. Your LCD is damaged and possibly the digitizer. You probably shouldn't attempt yourself... there may be a video on you tube, but you need to be handy and careful, probably replacing the whole assembly as one unit.
The digitizer needs replaced if the the touch functions stopped working. The LCD sounds like it needs replaced. If you have the luck that I have, then you will only find places that replace the Glass, digitizer, and LCD. Not just 1 or 2 of the components.
I would by the parts you need off eBay or other online sources and take them to whoever you choose to have fix it. They should cut you a deal for supplying your own parts and it saves the risk of them not having what you need and having to order it themselves prolonging your time of getting it fixed. Just a lil fyi
