lg g2 HELP
  • Start date Start date
A
Android Question
Guest
i recently had the new update on my lg g2. the 4.4.2 and since then all my data has shut off. I can no longer get on the internet at all on my phone in less I am on wifi. my phone is at&t but is a straight talk. is there anyway I can uninstall the update or fix this/??
Do a factory reset and see if you get your Data/WiFi back.
If that don't work,Then you can return to Stock here: LG G2 Stock Firmware (Go Back to Stock) | LG G2 | XDA Forums
Now if you choose to return to stock,Be sure to remove your sim card before flashing back to stock,As it will be wipe clean.
EDIT: Use the TOT method,Its easy.
i already did a factory reset and it didn't help at all. only deleted my stuff. I am willing to do the return to stock but am nervous on what to click on to do the process
Just follow the instructions word for word,And read it a few times before you start.
Your going to need to use the AT&T TOT method,And remember to remove the sim card before you start.
Have you checked the APN settings,making sure they match up w/your service provider?
