Hello, I need some help with my problem with the LG G2. When I try to connect via wireless the phone connects to the router and after a few seconds it's disconnect. I try several places and it is the same problem.
Do any of you encounter this problem?
No issue here with wireless. If you area running stock and a factory reset doesn't fix it then get a replacement. If you are running a cm based rom then there is a bug with bluetooth and wifi that you might be experiencing.
