Lg G2x
brdo
Hi, I have LG G2x phone and problem with network.
I'm in Europe and I got a NEW unlocked, rooted T-mobile G2x
Android version 2.3.7
CyanogenMod-phoenix HellFire v2.1
When I insert my Sim card no network present
"Mobile network not available".
I try with two SIM card but a get same message.
I try with some other solutions but they work with only
for android v_2.3.3.
Rooting doesn't work too.
Have you any suggeston???
Thanks
Welcome to the AF, look around and enjoy. :beerglass:
Be sure to check out the sections dedicated to your Android device and your Carrier.
Also if you want to be able to connect to the Forums from your Android device, be sure to check out the free Phandroid app in the Google Play Market. Cheers!!!!
this is the best place to get the proper help you need, LG Optimus 2X
Thanks
Hello and welcome aboard. Hopefully one of our many experience members who is familiar with your rooted device might chime in to help.
Good luck. ☜
