I have a relatively new LG G4 (August 2015). The rear camera isn't working properly - it opens with a hot pink background, it jumps around, then the camera app closes. Anyone else have this problem?
Sounds like a fault with the phone. When did it start happening? Was there a software update or anything? If not check if you have one you can try and install to fix. If not it almost certainly will be a hardware fault and will be covered under warranty.
