mill3rkydd
Does anyone have the APK to LG Home for android 2.2.2? I dont have it on K3LSOMOD.
if you like the look of the Home apk then try ADWlauncher from market. the EX version is pretty extensive compared to the LG home options app..since your on a custom ROM and its not added, i would try that. not sure if the HOME apk would work, you might need the home Launcher for that also, I know one wont work without the other.. and you would need the Odex file for LG home launcher and LG home also.
