LG Ignite System Update
  • Start date Start date
A
Android Question
Guest
Hello,
I have an LG Ignite (Model Number LG-AS855) (Android Version 2.3.4) My current carrier is with Element Mobile in Wisconsin. I have tried several times to perform a software update however every time I try, it says "Current version is the latest version." Under the "Update History" tab, it clearly states that it has not been updated.
I realize that there are many newer, nicer versions better than "Gingerbread" such as "Ice Cream Sandwich" (4.0-4.0.4) and even "Jellybean" (4.1-4.3)
I was wondering if there is any possibility if ANYONE can walk me through the possibilities of updating my LG Ignite.
I have read tons of forums, tried Samsung Kies, and asked my carrier. I believe by rooting my phone I could perhaps update the firmware, however I do not understand "rooting" too well (other than a broad overview of SuperOneClick and simple terms) and because of this am hesitant. If someone is willing to walk me through simply how to root and use the root to ONLY update my 2.3.4 version to something better that would be great!
Please help me!
Thank you,
-Troubled Android User
Root isnt just to update rooting your phone simply unlocks inner capabilities, however if you want to update your phone youd have to get a new ROM. If your running 2.3.4 its unikely that anyone has a ROM for your phone that is 4.0 or higher, however it is possibly with research. you can however put a bloat free rom on there like Cynogen mod 7.
LG Ignite root forums
Click the link above there are several posts and it will show you how to root your phone, if ROMs are available they will be in there.
Hi redjama,
Thank you very much for your timely response. I don't know why, but I couldn't log in earlier, so I submitted as a guest.
In regards to your reply: Thanks for clarifying specifically what "rooting" is.
I went over to the forums you linked for me and I was wondering if you could describe the process of using Craptorman's "ZV2 Craptorman_Mod_1.0 beta" mod. I can see the "to install" however I'm not sure exactly how to go about doing this, if I have to root my phone 1st, and more specifically WHAT this "mod" will do for my LG Ignite.
Thank you again,
-CCook17
