ismael nehme
I just got my lg k8v and i'm using a lot of data and I don't know why. The system data is enormous and my family thinks its because of pokémon go. Is it because of pokémon go and if or if not how do I make more space.
No Pokemon Go only uses data when it is running and that is when the app is open. Otherwise it stays completely dorment. I had issues like that far beyomd Pokemon go. Look in your settings and find the data monito section and that will tell you what is using the most data.I just got my lg k8v and i'm using a lot of data and I don't know why. The system data is enormous and my family thinks its because of pokémon go. Is it because of pokémon go and if or if not how do I make more space.
Are you talking about mobile data or cache data? Go to Apps>Pokémon GO and look at the storage.
yep. is that the culpritHave you taken an OTA update recently?
