Help LG Knock Feature
Lana30
Hi Friends,
If Android 6.0 disable´s the knock feature on an LG phone, is there a way to get it back or is that a bug one would have to live with until a fix comes? Thanks in advance. ;)
But I would try a factory reset,To see if it will work on Android 6.0.If you decide to go this route,Be sure to backup all your data before hand.
It must be a bug and you have to deal with it until they put out a fix.
Thanks for your reply. ;)
