lg leon lte
JohnD28
I need help. Was pretty happy when I rooted my phone using kingo root then my dumb self desided to factory reset it cuz well the phone wasn't mine. Worked fine to but then it was asking to update well all phones ask to update after factory resetting it so I try doing so and that's when everyone went to hell it was updating fine when an error word then this no command word popped up and this picture with it. Tryed using the bottoms to factory reset and the picture popps up again saying no cammand and it's stuck in a loop then logo then the no command again. What should I do?. Did it brick?.
Boot into download mode. Usually power off and disconnect the usb cable. Then hold volume down and connect the phone to the PC. Open flash tool, set the com port to 41 or higher in device manager. Then select the KDZ file and press start, at 85% or so it'll say fail but the device will be almost finished booting up and you can ignore the error.
