Root Lg marquee ls855 rooting help
I'm new to this rooting thing. This is really making me mad. I have been trying to root my phone for a whole week.
I have an LG Marquee LS855 with the newest update ZVC
Just keep trying. A lot of people have to try many times before their phone will root. Just follow the instructions to the T and it should work for you. I think that I had read that there is another way to root the phone. Just can't remember where I read it. :-/
It's all about the timing
Boost- as soon as you see the working symbol on the computer, power on the phone.
Sprint- it's supposed to be around 12 seconds. I got the boost version second try. :) don't give up!
Make sure you're using the KDZ update tool as an administrator and that you have java environment 1.6 or newer, also if you're a boost mobile user right after you clock update you turn on your phone, if your a sprint user you have to wait 12 seconds, timing is everything, also make sure its in smartphone mode.
i have been having issues rooting all week as well i can only assume that its the phone drivers since i have had other phones plugged in to my computer my driver is adb something or nother by google i have tryed many things to remove that driver and us the LG driver how ever the KDZ updater to get so far before failing
Error
WParam: 100
LParam: 72
[R&D Test Tools Log File]
13:55:45 : Launching SW update
13:55:45 : Unpacking KDZ
13:56:35 : KDZ file extraced
13:56:44 : Files were extracted.
13:56:44 : LGMobileDL Load.
13:56:44 : Port = 0
13:56:44 : Connecting to phone
13:56:51 : Check Phone mode = 1
13:56:54 : Phone type check.......
13:56:54 : LGMobileDL.DLL Loading....
13:56:55 : _SetAuthMark Ok : wAuthMark(17950)
13:56:55 : _DetachDLL Call
13:56:55 : _DetachDLL Call End
13:56:55 : Param : Path = C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\LS855ZV9_11.S9_00.P60680.wdb
13:56:55 : Param : moduleDir =
13:56:55 : Param : waitTime = 0
13:56:55 : Param : UsbHighSpeed = 1
13:56:55 : Param : PhoneMode = 1
13:56:55 : Param : BinVersion = LS855ZV9_11.S9_00.P60680
13:56:55 : Param : AuthMark = 17950
13:56:55 : Call fn_StartUpgrade
13:57:46 : CDMA: wParam = 100, lParam = 72
13:57:46 : Step : Upgrade Error2 - Error Code : 72
13:57:46 : ResetStartInfo() Call
13:57:46 : _DetachDLL Call
13:57:46 : _DetachDLL Call End
13:57:46 : FreeLibrary Call
13:57:48 : FreeLibrary Call End
13:57:48 : ResetStartInfo() Call End
13:57:48 : ===FINISHED===
13:59:07 : OnModelDllMsg(OnMsgFromModelDll-CDMA) delete m_pLGCyonUpdate
I have an old computer 3.0ghz 2gig ddr2 with xp sp3 so i have started by trying the turn phone on right on time to watching a stop watch and i found that i get the above resalts at 32seconds the phone never stops or slows down booting. if i wait to 36 seconds the KDZ doesn't connect.
Anyone near northwest Ohio north east Indiana Michigan tri-state area I can visit and be educated
Error
WParam: 100
LParam: 72
13:56:44 : Port = 0
I've heard some people had problems with sp3 on xp. Make sure everything is up to date. If you still can't get it, see if you can use a friends computer with a newer os. I used 7 and didn't have a problem. Rooted first try
Sent from my LG-LG855 using Tapatalk 2
Error
WParam: 100
LParam: 72
13:56:44 : Port = 0
Since you're already at param 72 you should be almost there probably about a second or 2 on the timing I posted something similar to this on the rooting thread just do a quick search for all the people with the same issue as they say just keep at it its really frustrating though lol
