Help LG Motion 4g MS770 Phone Bricked
My phone is bricked. I have tried all types of available fixes. Some links don't work anymore to download the different drivers and such. My phone automatically downloads driver 13.044... or whatever and I can't find the right downloads that accompany that particular driver.
Is your phone hard bricked or soft bricked? If t is soft bricked then you can fix it with ease but hard bricked means that you cannot fix it unless you change the broken parts. If it is soft bricked then try downloading odin and reinstalling the firmware for the phone. If that doesn't work, then it may be hard bricked. What action were you performing on your phone?
Odin only works with Samsungs afaik.
I could be wrong
OP have you tried a factory reset in recovery?
