Help LG Motion 4G no connection error help!!!!!!
B2_93
Hi guys i need help my phone will not connect. It was working fine and it happened to me before and went and i got it replaced but now it happened again youtube google play and my gmail will not connect i have a connection i can go on youtube and watch videos but if i try to sign in on any of them it will say that it can not connect to the network and i tried using my 4g and my wifi doesnt connect either way please help :(
Just had the same thing start happening to me on my LG Motion...
Shows as having 3 bars but no data connection. Going to have to get it replaced :mad:
They better not give me any trouble about a warranty. Thing isn't even rooted.
My phone use to do that , for about a week on and off like half a day . it just went away after I installed a ROM . alpha was really fast for me . that 3g was outrages , compared to the data being basicly out on stock . so then I just installed mini f and i havent had that problem since .
Hey bud, for me it turned out to be that my mobile data setting somehow got turned off under system settings>data usage>mobile data. Stupid but simple in my case at least.
Wow! Thanks. I installed an app that turned of my data. It would not turn it back on. I kept searching not knowing what the app had done. When I finally came to this thread. Thanks. It was just that easy on my motion. Turned data back on. Boom. 4g back. I am very thankful I kept searching before trying the factory reset suggestion. Thanks again.
