GreatPhones
My LG P705 Optima has a whole of script letters/phrase appearing over the screen, which seems to be actively working. A bit like DOS script working. There is also an extra highlighted bar across the top of the screen. Also when I drag my figure across the screen a blue scratch line appears, following my figure.
I down loader AVG antivirus app, did a scan but still have the same problem. I re started the phone. I turned it off, removed the sim and battery then re-place component and restarted. Still have the same problem.
The phone is about 2 years old.
Anyone had this problem? Is the phone dead, dying? Or is there a setting problem.
I am not keen to reset factory setting and lose all my data and contacts.
Any solution out there?
