Help lg optimus contact help
d32083
My lg optimus s has been running poorly recently so I decided to reboot it so I exported my contacts to my sd card. Then removee the sd card. After the reboot. I went to my contacts and attepted to import from my sd card. And i was unable to retrieve my contacts. After several attempts I kept getting a message that said Sorry! The process aneroid.process.acore has stopped unexpectedly. Please try again. Then it makes me force close. I opened the sd card on my computer but it won't let me open the vcard. If someone has any advice I would greatly appriciate the help
You say
Then you say
But how can you import anything from a removed SD card?
Besides, your calendar and contacts should also be available on their PC equivalents; here and here. And further, they don
After you exported your Contacts to your SD card, did you go to the 'Settings' menu and actually dismount the card before removing it or did you just remove it from its slot? If you didn't dismount it first, the data on the card might be corrupted. If you've got a laptop or PC with a card slot you might try mounting your SD to see if the whatever files you copied to it are there and readable.
