KarmaHunter
Member
Hi all.
So here's the story: I have a MetroPCS LG F3 factory unlocked. I moved to Mexico and I believe my phone got an update from the mexican company (Movistar) since I got a message to reboot my device to update the new features. And softbricked my phone...
Here's so far what I have done to the phone, which the only thing done to it was root it with Kingo root:
* At boot, I was getting the LG logo and a certificate validation error. I can enter Download mode and Emergency mode.
* Hard reset screen has no menu but it will reset it, get the android with blue wireframe in the belly. No go fixing it and will go into Qualcomm mode
* Tried LG Mobile Support Tool but it was getting stuck at 4%. Tried many time and 3 different systems. No go.
* Tried to flash MS659 KDZ without success.
* In Qualcomm mode, I was able to use BoardDiag and redo the partitions. Phone booted fine and got excited. Turned off to insert sim and after that NO GO.
As of right now, phone is stucked in LG logo, sometimes with the HOME button LED off and sometimes with the LED flashing in colors. I can enter Emergency mode, Download mode, and perform the hard reset. No go flashing with any of the above software either.
In Qualcomm mode, using DiagBoard (which helped the first time) will do the AP test fine, but can't do the EMMC since it will fail and disconnect the phone.
I have the original MetroPCS files for this phone (F3 Optimus): KDZ, TOT, CAB and the MS659.dll
Any suggestions to try before I play frisbee with my phone???
