healthylaff
I took a break after unlocking, rooting, moving files/apps to External microSD using Link2SD (a version obtained by torrent), and de-bloating my MetroPCS LG Optimus F6 (MS500).
After a couple months of normal use, it's been running worse and worse--locking up, long lag times, closing programs in the middle of use, etc.
So yesterday, I did a search for "LG F6 update" and found these two suspicious links (because they want the user to acquire some "downloader" to obtain the alleged Android 5.0 files and watch a video, which I've experienced on Torrent Sites and are usually loaded with malware or worse):
http://www.upgrade-lollipop.org/2015/02/lg-optimus-f6-5722.html
http://www.442kitkat.info/mp3-0/lg-optimus-f6-5722.html
If you look at them, they're obviously from the same entity.
So, TWO QUESTIONS:
So, TWO QUESTIONS:
- Any comment on those links and viability of some Android 5.0 Lollipop update (much needed for anyone with this LG F6)?
- Any step-by-step guide to getting my existing F6 back in decent working order? BTW, I did not hack the OS, just what's bolded in the first line above.
