T mobile prepaid got the l90. Which seems to be the same phone except it has a 4.7 inch screen and the same 1.2 quadcore s400 processor that the g has. There selling it for 180.
so mister shabby do you think the root for the lg f6 will work on this new lg l70?
thanks
normally id say absolutely not. i mean its 4.4 so just about every exploit should be patched (including loki for using custom recoveries etc). but it is lg and who knows, they are terrible for security.
Thanks. Although I'm not going to be using the L70 at all for a primary phone, I just wanted to know if I had future use of the Metro sim card if I bought a t-mobile phone for a family member, or if that sim card was tied to the L70....... Also, with Metro PCS we still can only have one active phone per account right? I couldn't register a second phone and switch gsm at free will?Pop it in your s4 and goal thru the pairing process
Last question, I'm using the L70 as a wifi device, so naturally that alert of no service and no sim card is on the status bar and on the home screen. Any way of disabling that? I wouldn't mind the "no sim card" notification on the status bar, but it's a bit annoying on the actual home screen.
No with metro you have to call and give them the imei of the phone and the sim is tied to the phone. Its a carryover from there cdma days. You cant just pop your sim and and place it in any gsm phone like you can on att/tmobile.
The second question i believe is no to. I havent used an l70 but on other devices there is no way to remove that. I cant see the l70 being any different.
any verified root for the metro lg l70 / lgms323? have tried about everything. cannot even boot into stock recovery
Super lockdown so far but give development time can you use fastboot commands
does the lg optimus l70 will have root or is to cheap to waste ur guys time?
is root for this going to take a bounty or is it just gonna take till a dev gets this phone in their hands?
