Hi, I have an issue. Imam the current owner of an Optimus v from virgin mobile. I successfully rooted it, but I then I attempted to to a reboot of sorts and it now does the lg thing when it's turned on, the vm thing, but then the screen is black. HELP!?
Hello aries, welcome to Android Forums. I'm sorry you are having problems. You will want to check into the root area for your phone for the best support for your problem. Here is a link to that area. Optimus V - All Things Root - Android Forums
