Hello martimus i am having the same problem and wifi sleep option is already set to "never". It's strange because it was working perfectly 2 days ago but now it shows connecting and then it disconnects and starts to scan again. This procedure is happening with every wifi network i am trying to connect.
Hi Martimus,Welcome to the Android Forums!
Did anthing of significance change with your phone 2 days ago? An update from the carrier? A new app installed on the phone? A suspicious force close message on the phone?
Have you tried rebooting the phone. Sometimes by power cycling the phone you can clear up a quiky issue.
Another thing to try would be to go to the Wireless & Networks app in Settings. Toward the botton of the screen should be an entry called "Manage Networks". Go into that and select the network that's currently not connecting. Instruct the phone to forget that network SSID and then attempt to re-connect to that network. Sometimes I've noticed that re-connecting to the network SSID seems to resolve connection problems.
