So a while ago, I found some LG G2x and I want to use them, the ting is that both have problems.
1. One of my G2x has a problem where if I plug in the phone to a wall and try to turn it on, it would show LG logo then the screen would turn black and it would do that repeatedly. If I unplug it, then it does not even work. It never charges and never turns on.
2. My second G2x never even charges at all, the charger fits perfectly, but nothing happens.
Any help?
Please respond if you know a possible way to fix these problems.
I want to use my G2x again.
Any help?
