D-U-R-X
turbo drinker
This is a work in progress and, as such, if you feel that there is anything that needs adding, please PM a guide or start a thread in Private Chat With Staff with your suggestions.
Many thanks
1. General Android phone FAQ's?
2. How can I improve my battery life?
3. Are there any Revolution Tips & Tricks?
4. What are the known problems with the Revolution?
5. Forum related questions.
6. What is root?/What does being rooted mean?
7. How can I fix/replace my screen?
8. How can I check for updates for my LG?
Q: General Android phone FAQ's?
A: Here is a thread on general Android Phone FAQ's
Q: How can I improve my battery life?
A: You should check out this thread: Battery Life??? and this thread: Juice Defender is a lifesaver. You do not have to follow the tips offered, but they should help. Smartphones operate on a sort of spectrum... on one end you could put battery life, on the other end all those options like wifi/3g/sync (among other things). If you want great battery life you can't have those on all the time. If you want those on all the time, you won't get great battery life. It is best to find the compromise that works best for you and what you want most out of your phone.
Q: Are there any Revolution Tips & Tricks?
A: For any Revolution Tips, if you use the "filter by" and select "Tips" in the sub-forum, you will get many useful tips and tricks.
Q: What are some of the problems people have with their Revolution?
A: For any problems and their colutions, if you use the "filter by" and select "Support" in the sub-forum, you will get many useful tips and tricks.
Q: How can I fix/replace my screen?
A: This thread has step by step instructions: How to repair LG Revolution screen
Q: How can I check for updates for my LG?
A: Here is a thread detailing that
Many thanks
