Root LG Spirit Mobile Data Connection Problem
brandons7
Hey guys,
I'm having some trouble with my LG Spirit 4G from MetroPCS. Up until this morning it has been able to connect to mobile data just fine, but when I tried today it won't. I used the "spirited away" root, had Titanium Backup installed (the premium version), and have already performed a factory reset, all to no avail. Any suggestions?
EDIT:
When I go to "Settings > About Phone > Network > Mobile Network State" it says disconnected. Whenever I attempt to connect to my mobile network it says "connecting" and then shortly after (1-2 minutes) goes back to showing disconnected. Here is all the data from that page:
Network: MetroPCS
Signal Strength: -94 dBm 2 asu
Mobile Network Type: EvDo-rev.A
Service State: In Service
Roaming: Not Roaming
Mobile Network State: Disconnected
Channel: 325
SID: 6503
IP Address: Unavailable
Supported Technology: CDMA 1X: 850/1900/1700/2100
CDMA 1X EVDO Rev.A: 1900/1700/2100
LTE: Band 2, Band 4
Hey guys,
Not really sure how to fix this problem. You could try to toggle airplane mode on then off and see if it works. Also check to see if you have the data enabled box checked. That's all the stuff I can think of so hopefully someone with more knowledge can drop in and help you.
Just tried this, still no luck. :/ Thanks for the suggestion though, I'm open to just about anything right now.
I got a ? did we get prl update after 3035.can any let me know if so when. On my phone I don't got prl version 3035 anymore I got 1005 and mobile network type I got LTE not evdo.if we did I'm late been busy..thanks in advance.
you are suppose to be on lte, that's 4g. EVDO is 3g. As for prl version its still 3035. At least in my area.
Y
Network: MetroPCS
Channel: 325
SID: 6503
LTE: Band 2, Band 4.
I phone info was like this also and I had 4g (EvDo-rev.A).But what I'm staiting is that were the EvDo was it has changed it says LTE in that spot now.
Y
Network: MetroPCS
Channel: 325
SID: 6503
do you mean in your status bar?
this is how mine looks.
Network: MetroPCS
Signal Strength: -105 dBm 16 asu
Mobile Network Type: LTE
Mobile Network State: LTE
Channel: 725
SID: 6504
I'd say call *228 on your cellphone. and try updating your roaming list
