Help LG Thrill Restore Problem
afx2
Hey everyone-The Lg Thrill I have seems to have become corrupt, so that every time it reboots, it's stuck in the same settings and applications. Every time I reset, any applications or files I installed are gone, and all of my settings are reset to the way they were in a past state. I've done the all the resets possible and still no luck. Is there any way to fix this?
I would recommend a factory reset (hard reset) instead of just a battery pull.
That will take your phone back to stock, and wipe all of the previous settings, so that won't keep happening.
That's the problem. I have done multiple factory resets attempting to wipe the phone and it still reappears untouched, as though it's imaged with that state.
Wow! I am at a total loss for why that is happening to you, but it may be time for a visit to your service provider or nearest service center for some advanced troubleshooting.
