Help LG V20?
Nothing but problems with my Note5. Excited to finally upgrade.
Have no clue what to get. Scared to get a Note 7. FAA won't even let you use it on a airplane.
iPhone? Don't think so. I want at least 5.7 screen and a headphone jack.
Should I try the V20? Looks pretty awesome. Or should I wait for the upcoming Google phone? Thanks for your help.
Really depends on what you plan to use it for, movies, drawing, reading, research and forum posting, list goes on. But size matters as always and the Google phone might not be your best bet as the screen size isn't as enduring compared to the V20.
Check out the two links, but I would recommend resolution and quality over brand names.
The Note 7, in its defense, is a fantastic phone. It's just having a few little "issues" right now :p
But once those are all cleared up, and that should be very soon, it will be the flagship to beat.
