My rooted Boost Mobile LG Volt (LS740) Android 4.42 ROM version LS740V6 does not show a voicemail notification icon whenever I receive a voicemail. I can retrieve the voicemail just fine, just no notification.
Phone is now on Sprint network instead of Boost Mobile. If I flash custom ROMs such as Bliss, CM12 or CM13 then I get the notification just fine...but those ROMs have their own issues so I prefer stock ROM.
I think it may have something to do with stock ROM was designed for Boost Mobile's voicemail system instead of Sprint's so it's not intercepting the call. I tried flashing different versions of voicemail apps, installing 3rd party apps from Google Play Store, and removing native voicemail apps but none worked.
Any ideas? Thanks.
Any ideas? Thanks.
