Help LG Volt stuck in recovery mode
My LG Volt is stuck in recovery mode and I don't know how to get it out of it. Yesterday I flashed the CWM on, and it was working fine, but today I clicked on the update for the phone and now it is stuck. I keep rebooting it, and it keeps going right back to the recovery [CWM] I tried to flash 2 different LG Volt Roms, and they were both were successful but as I reboot the phone it returns right back to the recovery. I have tried everything such as 'wipe data/factory reset' and 'wipe cache partition' can someone please help?
Installing the update with CWM has soft bricked your phone. Your first problem is CWM. You should be using TWRP. In the rooting forum, there is a stickied thread titled Brick Recovery. Follow that and allow your phone to completely update. Then follow instructions in the All Things Root post to reroot and install TWRP.
Also, where did you get the CWM from? There is one for our phone, but it's been buried in the forum. I find it surprising that you stumbled across it. If you got it from somewhere else, then it probably wasn't for this phone and the damage may be irreversible.
Thanks it worked! I followed your tutorial a long time ago for another reason, but I could never find it again for whatever reason. But it works now, thanks! And I did have TWRP at first, but TWRP would never let me install any updates to the phone or ROMS so I decided to go with CWM. Anyways I got CWM from here http://androidforums.com/threads/working-cwm-recovery.880181/
Glad you're fixed. Seriously, don't use that CWM. It's bugged and not safe. Not sure why you were having issues with TWRP, unless it was one of the older versions. The current version (2.8.7.0) is all good.
Regardless, don't install OTA updates with custom recovery installed. It likely will soft brick. We usually have update ROMs available shortly after an update is released.
We need to get the mods to fix that thread.
I have troubles navigating n finding certain topics/threads using xparent tapatalk, where can i find the twrp recovery 2.8.7.0?
