Root LGLS720 Stuck on BOOTLOOP
SO I rooted my phone and downloaded a custom bootup animation a while back. I restarted my phone yesterday and it finally took effect. IT stays stuck on the screen, the animation keeps on going but my phone never really boots up. I have tried factory reseting and going into recovery mode. I have had no success and need help. It is at version V8 and I used a root from mgyun called I root. I downloaded custom animation on an app and now my phone seems to not boot up at all
Can u get in recovery?
Honestly, I don't know how, I got the LG Flash tool 2014
U have twrp for ur recovery right if so down load a ROM put on root of ur SD card then shut off phone boot up in to twrp make sure it set to see ext SD then home screen on twrp u see install click it then u should see ur ROM then click it it will do all the work for u u will lose any thing on the internal SD take ur time rember google ur best friend there is a utube bid on it if I rember right good luck hope this helps exclusive 36 is good with this phone
Where do i download the rom?
If you did not factory reset we could have fixed this issue.
