Apps [Lib] RippleDecoratorView - Configurable Ripple and Highlight effect backwards compatible with up to
RippleDecoratorView is a widget library with a view used to wrap any of your layouts. It allows you, for any touch, to add animations effects such as: ripple stroke, ripple fill, highlight, and zoom. These animations come with a configurable fade-in, fade-out timeline.
It does not capture touches, so you can pepper it safely though your XML layout files.
It comes with an example project and is already available at Maven Central.
Github Repository: https://github.com/thomsonreuters/RippleDecoratorView
And if you want a q&d introduction, just add to your dependencies
Code:
compile 'com.thomsonreuters:rippledecoratorview:+'
and wrap any of your views with
Code:
<com.thomsonreuters.rippledecoratorview.RippleDecoratorView
  android:layout_width="wrap_content"
  android:layout_height="wrap_content">
    <Button
        android:layout_height="wrap_content" />
</com.thomsonreuters.rippledecoratorview.RippleDecoratorView>
