Apps Library to analyse picture (colors, size)?
Winfried
Hello
To get started with Basic4Android, I'd like to help a friend who works as a nurse and develop an application that can take a picture of a wound and return infos about its colors and size, so as to monitor how the wound evolves and what type of bandage to use.
I read about OpenCV, and I was wondering...
  • if OpenCV is the right library for this (apparently, it does real-time image processing, while I just need it to analyze pictures taken by the smartphone)
  • if not, are there other libraries available for Basic4Android that I should check instead?
Thank you.
