andyacecandy
This is very annoying. Light Flow works... but then the LED just stays blinking even after I read my text message. Any idea how to get it to automatically turn off once I actually read the message?
I think if you go into Lightflow, and tap on Notifications, Then tap on the notification you want to edit (apparently it is text messages in your case), then you can select the "Clear Notification Style". There are three options. I think you want option 2, "Notification Removed".
In Textra settings, try:This is very annoying. Light Flow works... but then the LED just stays blinking even after I read my text message. Any idea how to get it to automatically turn off once I actually read the message?
